أحمد إلياس
2024-11-23 07:59
Recently, the temperature is close to zero degrees. After starting the car, the water temperature rises very slowly, taking about ten minutes to reach 90 degrees. During the temperature rise, the car shakes a lot. Could it be because of the weather?
سلمان رمضان
سلمان رمضان2024-11-29 21:41
When it's cold, start slowly and wait for the temperature gauge to move before accelerating.
Is it normal for the water temperature of a 2015 Peugeot 508 to be around 90 degrees? [crying][crying][crying]
Why does the right front wheel of my 2019 GA6 get about ten degrees hotter than the other three wheels after driving for a while? When I touch the hub, the temperature difference is quite noticeable.
Is it normal for the idle speed of a 2015 Volkswagen Touran to rise to 900 RPM when the outside temperature is below 0 degrees while the engine is warm?
The 2019 Yuexiang has a strange noise from the belt area when starting in sub-zero winter temperatures, but it goes away after a few minutes. After inspection, no issues were found. What's going on?
How can I fix the issue of the engine noise being very loud when starting the Alto 1.0 when it's cold? The sound normalizes once the water temperature reaches 20 degrees.
I have a used Suzuki SX4 AWD with 130,000 kilometers. In extreme cold weather (minus 40), it drives very steadily. However, when the temperature rises to around 5 degrees above zero, it feels a bit floaty and unstable at speeds of 80 to 100 km/h. Can fellow car enthusiasts offer some advice?
Hi everyone, when I drive fast and press the brakes a bit hard, there's a thudding sound and the brake pedal feels like it's bouncing. This doesn't happen when I'm driving slowly or pressing the brakes lightly. Is this the ABS system kicking in or is it an issue with the brake pads? Also, regarding the temperature gauge on the dashboard, I remember it used to show two bars as soon as I started the car, right in the middle, but now it takes a few minutes to gradually rise half a bar at a time. Am I remembering wrong or is the coolant level low?
Is it normal for a 2014 Peugeot 2008 1.6 automatic to have the engine temperature rise very slowly, taking over ten minutes to reach 70 degrees? Could it be that the engine oil is too thick?
Help needed, fellow Peugeot owners! Ever since my little Peugeot went on a continuous uphill drive for over an hour a few days ago, it's been having issues. The RPMs go up, but the speed doesn't. It's not too bad when not on the highway, as pressing the accelerator quickly gets the RPMs and speed up. But once I'm on the highway and going over 80-90 km/h, I need to press the gas to at least 2000 RPMs for the speed to increase very slowly. On inclines, if I don't reach 2500 RPMs, the speed drops. I never had to go over 2000 RPMs on the highway before. What's going on? 🌹
Don't rush to buy this car just yet; wait for three to four months as a new model will be released. The 2025 model will come out early next year. People are interested in this car mainly because of its zero fire risk and sincere configuration. Be prepared for the following if you decide to purchase this car: 1. The overall electricity consumption is over 20, and it might be even higher for men driving it, considering the car weighs 2 tons. 2. The car has severe nose diving when you brake, causing it to wobble a few times. 3. The sound insulation is poor; you need to close the doors with force, and dust easily gets inside the car. 4. Repair parts are as expensive as those for Mercedes-Benz and BMW. 5. The seats, while known as "Nissan Big Sofas," are not as comfortable as those in the Sylphy. 6. There are quite a few minor issues and faults, with the car's system being a significant drawback.
Peugeot Peugeot 408
Peugeot 408AED 129,000Gasoline
