عبد العزيز بشير
2022-05-03 21:21
Why is the clutch master cylinder of my Haval leaking oil after running less than 20,000 kilometers?
Comments( 6 )
سعود نعيم
سعود نعيم2023-06-22 08:11
With 47,000 kilometers on it, I noticed there's a slight oil seepage, but it's not serious! The engine valve cover isn't leaking either, so the quality is quite good! It drives well and feels much more refined compared to domestic brands. It's really fuel-efficient, only 4.9 liters for commuting to work and back! The road conditions are good with few traffic lights. [Thumbs up] The more I look at it, the more I like it! [I want some peace and quiet][I want some peace and quiet] Even if these minor issues arise, fixing them doesn't cost much! The quality of the core components is rock solid!
فهد تكريتي
فهد تكريتي2023-05-31 19:06
Just get the OEM one.
سلمان فاتح
سلمان فاتح2022-06-15 09:49
Common Issues with Kia
سعود ستار
سعود ستار2022-06-14 07:20
Replaced two and solved it.
20
سعود جلال الدين
سعود جلال الدين2022-06-04 17:30
I have replaced both my master cylinder and slave cylinder.
حسن عل
حسن عل2022-05-03 22:09
It might be because the oil seal is damaged. Try going to the 4S shop to replace the oil seal.
Hey folks, have any of you experienced clutch master cylinder oil leaks? It seems like the leak is at the connection between the master cylinder and the oil pipe. Is this a common issue?
Does your engine cylinder head leak oil?
Why does the 2022 Nissan Altima have a door noise issue? The car is brand new and has less than 1000 kilometers. Looking for advice from experts.
Is anyone selling a 2019 720S Coupe with less than 10,000 kilometers?
I just bought a second-hand car and after driving it for less than 1000 kilometers, it consumed 2.5 liters of engine oil (it's a 5-cylinder car registered in 2014). I'm not sure if any of you experience this oil consumption. Should I switch the engine oil from Shell 0W-40? What should I do, any advice for a budget-friendly solution?
I last changed the oil in August last year and have driven less than 10,000 kilometers since then. Do I need to change the oil now, and what's a good type to use?
The Jietu 90 has too many issues. At less than 20,000 kilometers, the one-touch start fails to work, and the 360 camera malfunctions, sometimes even resulting in a black screen.
I'm driving a 2021 1.4T Comfort T-Cross, and it's run less than 20,000 miles. There have been two instances where it suddenly braked and paused while driving normally. What's the reason for this? Does anyone know?
Does your 1.6 naturally aspirated engine consume oil too? Mine has only run about 90,000 kilometers, and after the last maintenance, I drove less than 2,000 kilometers before the oil light came on. When I checked the oil dipstick, it couldn't even reach the oil level.
Kia Kia Pegas
Kia PegasAED 50,000 ~ 55,000Gasoline
