خالد هشام
2023-05-15 10:44
Which type of LED light is better for the Kia Pegas, and which brand? I've tried several LEDs but none seem to provide a good result.
حسن عبد العزيز
حسن عبد العزيز2023-05-20 23:12
It's essential to add lenses when upgrading to LED lights; otherwise, the upgrade might not be worth it.
Which configuration of the Navara comes with a rear locker? I checked, and it seems like none of them have a locker, right?
Is your 2018 manual KIA Pegas with 70,000 km experiencing difficulty in shifting gears, often failing to engage and grinding? It seems like the clutch isn't fully disengaging. Could this be a clutch issue or a problem with the gear linkage? How can it be resolved?
I tried several methods to enable the one-touch window up/down feature on the 2017 320T, but none of them worked. Any advice?
I've tried perfume, aroma diffusers, solid balms, and scent sachets, but none seem to work well. It feels like the car just doesn't hold the fragrance. What is everyone else using?
Which is better, the Kia Pegas or the Toyota Yaris?
If you're considering changing the tires for your Kia Pegas, it's best to choose a brand that is known for quality and performance. Popular tire brands like Michelin, Bridgestone, and Goodyear are often recommended for their reliability and durability. Make sure to select tires that match the specifications and size needed for your vehicle to ensure optimal performance and safety.
What brand and viscosity of engine oil are you using? I've tried several, but none seem to work well.
Which phone mounts are you all using? I've bought several, and none of them work well.
Any recommendations for which brand and type of engine oil to use for a 2019 Kia Pegas that's run about 65,000 kilometers, as a second-hand car?
Kia Kia Pegas
Kia PegasAED 50,000 ~ 55,000Gasoline
