The gear today successfully got stuck.
I just got my new car today, but the wireless charging keeps disconnecting. How can I fix this issue?
When driving at speeds between 50 to 70 km/h, should I use fourth gear or fifth gear? I've just got my license.
4I have a question. Today while driving, I noticed that the gear shift lever on my automatic transmission can be shifted without pressing the button on the handle. Is this a problem?
5Sometimes I feel like the gear is stuck, especially when starting the car. Have you guys experienced this situation?
6The Kia Sportage automatic stalled while adjusting the air conditioning in D gear at idle. It restarted successfully and has only happened once, otherwise everything is normal.
7The gear today successfully got stuck.
8Hello everyone, today after the car accident, it showed a transmission fault, and the gear can't be shifted from the P position. It seems like it's locked. What could be the problem?
9Steering feels stuck and doesn't return to center. How do you guys deal with this? I've heard it can be fixed by reapplying grease to the steering gear. How much does it roughly cost?
10Did you get your brake pads and brake discs replaced at the 4S shop? How's the quality? I just got mine changed today for 2500 RMB.
