My manual Kia Pegas has run over 20,000 kilometers. This afternoon, the malfunction indicator light kept coming on. I turned off the car and restarted it, but the light is still on. Seeking advice from fellow car enthusiasts.
Which type of LED light is better for the Kia Pegas, and which brand? I've tried several LEDs but none seem to provide a good result.
4One side of the rear tail light and reverse light on my KIA Pegas are not working. Fellow car enthusiasts, should I go to the 4S shop or just find a regular mechanic? 🙏
5Any recommendations for which brand and type of engine oil to use for a 2019 Kia Pegas that's run about 65,000 kilometers, as a second-hand car?
6The engine malfunction light on my 2010 City recently started flashing. Diagnostic code 14 indicates irregular misfires. I've replaced the spark plugs, ignition coils, and cleaned the fuel injectors, but the issue still occurs intermittently. Every time the light flashes, I restart the engine and the issue disappears for a while before reappearing. Any knowledgeable experts or fellow car enthusiasts have any advice on how to handle this issue?
7The dashboard is indicating a daytime running light malfunction, but I haven't noticed anything wrong. The daytime running lights are functioning properly.
8When starting the engine, the malfunction indicator light flashes briefly and then goes off after starting. What could be the issue?
9I've been driving my car for six years, and it's covered over 30,000 kilometers. Recently, while driving, the gear indicator on the dashboard disappeared, and the engine warning light came on, but the car was still running fine. I went to a repair shop for a check, and they said there was no problem and cleared the warning light. However, the warning light appeared again soon after, and the gear indicator keeps disappearing intermittently. Additionally, there's shaking when braking to a stop and when starting the vehicle. I'm seeking advice from the community!
10The car won't start, and the EPC, battery, engine, and malfunction indicator lights are all on. What could be the reason?
