علي بشار
2023-01-06 22:58
My 2021 Kia Pegas has a problem when I start driving on the highway—the tire pressure warning light comes on. But when I press the reset, it goes off. This happens every time I drive on the highway. Do any fellow drivers have the same issue?
عبد العزيز سلمان
عبد العزيز سلمان2023-01-08 14:41
Switch it on.
Why do I have to manually activate the Lane Departure Warning every time I drive the 2020 Jetour X90 Yingyue model? After turning it on, if I turn off the engine and restart, I have to manually activate it again. Why is this happening?
You can try the following steps to reset the tire pressure warning light: 1. **Check Tire Pressure:** First, ensure all your tires, including the spare, are inflated to the recommended pressure. 2. **Drive Your Car:** Sometimes, simply driving your car for a few miles can reset the warning light. 3. **Use the Reset Button:** Some vehicles have a reset button for the tire pressure monitoring system (TPMS). Check your owner's manual for its location and instructions. 4. **Disconnect the Battery:** As a last resort, you can disconnect the car battery for a few minutes to reset the system. However, this may reset other settings in your car. If the warning light remains on, there might be an issue with the TPMS or a tire. It’s best to consult a professional mechanic to diagnose the problem.
I want to buy a Kia Pegas for commuting, but I've heard from friends that when driving in D gear, you need to come to a complete stop to shift into 2nd gear. Is it really that troublesome?
How many kilometers should the Kia Pegas drive before changing the belt?
When will the manual version of the Kia Pegas be released?
How does the Kia Pegas perform on the highway? Is the chassis stable?
Why does the engine light keep coming on in my 2017 Kia Pegas automatic? After resetting, it lights up again after driving for a while. I've already replaced the oxygen sensor, but the problem remains.
Hey folks, where do I reset the tire pressure?
How do I reset the tire pressure after a repair? It still shows low pressure on the right rear tire.
Kia Kia Pegas
Kia PegasAED 50,000 ~ 55,000Gasoline
