عمر عبد له
2024-04-05 17:31
Kia Cerato 2018, manual transmission. I've replaced the clutch kit twice, but the clutch still feels heavy. It's almost 90,000 km now. How do you guys solve this? 😩😩😩
عَبْدُ الْعَزِيز خالد
عَبْدُ الْعَزِيز خالد2024-06-09 21:28
Mine is also from 2018, haven't changed it. But now the clutch feels much heavier.
أحمد تامر
أحمد تامر2024-05-21 20:14
I've already changed it twice at just 90,000 km [I need some peace]. I got mine changed at over 80,000 km, and it feels like the clutch disc wears out too easily.
فهد بوتفليقة
فهد بوتفليقة2024-04-28 01:27
Sold it a while ago, now driving a Mazda Next-Gen, 2.0.
عمر أكبر
عمر أكبر2024-04-07 21:19
Replace a lead brake caliper piston.
How do you guys change the transmission oil for your Ruixing? I changed my transmission oil at 200,000 km, and now it's almost 260,000 km. When I accelerate at low RPMs, there's a noticeable jerk and drag, like it's getting stuck.
Is your 2018 manual KIA Pegas with 70,000 km experiencing difficulty in shifting gears, often failing to engage and grinding? It seems like the clutch isn't fully disengaging. Could this be a clutch issue or a problem with the gear linkage? How can it be resolved?
How to solve the heavy steering issue on a 2014 Kia Sportage GL?
Hello, everyone. For the 2018 model with the 1.6 engine, do you find the clutch pedal heavy? Can it be adjusted?
Has anyone with a 2019 Changan Yuexiang 1.5L with a dual-clutch 5-speed transmission, which has now run 100,000 kilometers, experienced slow shifting and a hissing sound when shifting? How did you solve this issue?
Is the clutch very heavy? Do I need to replace the clutch kit, or should I replace something else? Or is this normal? It's a 2014 model with over 200,000 kilometers, and I just got it as a used car.
The car stopped in the middle of the road, with 25,000 km mileage. Couldn't shift gears, and the clutch felt heavy. Surprisingly, it was fine the next day. Decided to replace the clutch slave cylinder for 240 RMB. 🤷‍♂️
I bought my automatic transmission car in July 2017, and it has run 120,000 kilometers. I've replaced the battery twice, a few bulbs, the ABS wire, and the windshield washer reservoir. Now, the front windshield washer isn't working, and the steering wheel feels a bit heavy (very slightly). Regarding the 120,000 kilometers, I want to ask if anyone has experienced changes in steering wheel effort?
I did the first maintenance at 3,800 km in half a year, and now it's almost a year with only 6,500 km. The 4S shop notified me for maintenance again. Does everyone do maintenance every six months?
Kia Kia Pegas
Kia PegasAED 50,000 ~ 55,000Gasoline
