Is your 2018 manual KIA Pegas with 70,000 km experiencing difficulty in shifting gears, often failing to engage and grinding? It seems like the clutch isn't fully disengaging. Could this be a clutch issue or a problem with the gear linkage? How can it be resolved?
When using the paddle shift manual mode in the HS with the S gear, do I need to press the brake pedal to change gears? In the past, when I drove a fully manual transmission, there was a clutch pedal. [Facepalm][Facepalm][Facepalm][Facepalm]
The gear lever on this company car is problematic. After shifting to reverse, the detent stays in the engaged position even when you return it to neutral. You have to push it down to disengage. I didn't pay attention today, and when coasting downhill while pressing the clutch, I directly shifted to first gear without pushing the detent down. As a result, the car stalled and now it won't start at all.
4What causes difficulty in shifting gears in a manual transmission? Has anyone experienced this?
5I want to buy a Kia Pegas for commuting, but I've heard from friends that when driving in D gear, you need to come to a complete stop to shift into 2nd gear. Is it really that troublesome?
6The Kia Sportage has a jerking sensation when shifting gears.
7Where is the clutch slave cylinder located on the Kia Pegas?
8What could be the issue with the 2019 JETOUR X70 having difficulty shifting gears? The clutch master cylinder and transmission have already been replaced, and the issue has somewhat improved. However, sometimes it's still hard to engage first gear.
9Why can't I shift gears often after starting my new Defender 130?
101. Does anyone know if it's normal for there to be a "thud" sound when quickly releasing the clutch from first to second gear in a manual Suzuki Swift? 2. When pressing the clutch to engage first gear, sometimes there's a "thud" sound near the left foot. What's the issue?
