حسين يحيى
2023-03-03 23:41
Is there a pre-installed loudspeaker wiring harness and plug for the rear doors in the 2017 manual version of the Hyundai Reina? I'm considering adding a pair of speakers and would like to know if it's ready for installation.
نايف طل
نايف طل2023-04-02 19:53
I found someone to replace a set for me.
Hey folks, does anyone know if the rear door of the Automatic Smart Enjoy version has no loudspeakers, and if there are any pre-wired connections?
I just went to the 4S shop today, and I can't upgrade the car system. The original 360 camera is not clear and can't be calibrated. Regarding the transmission defect issue, the after-sales service at the 4S shop will apply to the manufacturer and get back to me. Also, I'm wondering if just changing the DSP will improve the original audio system since I don't like it. I'm considering the Pioneer 500A, which can connect directly with the original plug without installing separate loudspeaker wires.
I would like to ask if there are pre-installed wires for adding loudspeakers in the rear two doors?
Hi everyone, I'm asking a question here about owning an 86. I want to buy an 86 as my first car and I have enough money for a 2017 model. Does the 2017 model come with a reversing camera? Can I install front and rear parking sensors later? I'm quite reliant on sensors. If it doesn't come with factory sensors, can they be added afterward? Looking forward to your replies, thanks!
Hello fellow car enthusiasts, I own the 2019 Premium model. I'm considering installing all the missing loudspeakers without changing the main unit. How do you think the sound quality would be?
Chery Arrizo 3, sometimes there's a noise above the glove box. When driving, it usually stops, but after turning off the engine, closing the car door might cause the noise again. There's also a similar sound inside the passenger side B-pillar seatbelt. I want to take apart the dashboard to see if something is loose inside, but I'm not sure where to start. I've previously removed the bumper to install a loudspeaker and added a central control screen with a rearview camera. But I'm not sure how to start with the area above the glove box.
Kia Kia Pegas
Kia PegasAED 50,000 ~ 55,000Gasoline
