إدريسي عبدالله
2024-08-29 23:48
Is it normal for the fan to frequently turn on, with a particularly loud noise, and then stop after a while, even when the water temperature is normal? Has anyone experienced this? It also happens when idling, where it turns on once every few minutes.
عبدالرحمن يونس
عبدالرحمن يونس2024-10-26 00:30
This isn't normal, is it?
علي شمس
علي شمس2024-09-16 01:25
Check if the thermostat is faulty.
علي معتمد
علي معتمد2024-09-12 18:11
What issues have been checked?
خالد ربيع
خالد ربيع2024-09-01 20:41
Is the air conditioning turned on?
Why does the temperature in my Fuga always rise when driving on the highway? I've already replaced the fan module once.
Why does the water temperature rise when going uphill and automatically decrease when going downhill, or when turning on the heater with the air conditioning?
Is it normal for the 2008 imported Mazda 3 to have a cold start RPM of 1600, with a particularly loud noise that decreases after about a minute?
When driving, if the electronic fan does not start at high speed after turning on the air conditioning and the water temperature is high, how can this be resolved?
Is it normal for a fan not to spin frequently? I had it replaced at a friend's shop, but it's still the same.
The fan on my Sharan sometimes doesn't turn on even when the temperature is high. What could be the reason? Any advice?
When you start your 2019 model car and turn on the AC for the first time, you hear a noise like the fan suddenly stopping. What's causing this? It only happens once and then works normally afterwards.
How can I fix the issue of the engine noise being very loud when starting the Alto 1.0 when it's cold? The sound normalizes once the water temperature reaches 20 degrees.
When I turn on the air conditioning, the cooling fan starts spinning, then stops after a while. The cycle of spinning and stopping is roughly one minute. Even after turning off the car, the fan keeps running and won't stop. Only by restarting the car and then turning it off again does the fan stop. Could the temperature sensor be malfunctioning? Any insights from the experts?
Kia Kia Pegas
Kia PegasAED 50,000 ~ 55,000Gasoline
