فهد وهاب
Aug 16
I replaced the LED headlights, and now the headlight adjustment doesn't work. Does anyone know if this will affect the car? Should I go to the 4S shop to fix it?
Can I replace just the headlight adjuster for the March, or do I need to replace the entire headlight assembly?
Now that the car company has gone bankrupt, what happens to the maintenance services promised by the 4S shop? The contract was signed with the 4S shop...
4I recently replaced the headlight assembly on my Kia 2009 Sportage, and now I'm facing two issues: 1. The headlights can't switch between high and low beams. 2. The headlight level adjustment switch on the central control dashboard is not working; turning the switch doesn't affect the headlights.
5Are there no more 4S shops now, so should I go directly to a repair shop for maintenance?
6I replaced a pair of LED bulbs on my car, but now the low beam and high beam look the same. Any tips to adjust them to be lower?
7Should I replace the battery at the 4S shop or do it myself? I'm torn.
8The original halogen headlights on the Sharan were replaced with LED headlights, and they flicker during start-stop. Should I use 5054 to activate the xenon mode for the low beam to stop the flickering?
9Does not installing the electric pedal at a 4S shop affect the lifetime warranty? 💡
10How much does it cost to replace LED headlights?
