عبدالله فاطمة
عبدالله فاطمة
Mar 27
I bought my Hyundai Reina at the end of 2017, and it's been almost 4 years. Since January 2021, I've noticed that the front left wheel pulls to the left. When I let go of the steering wheel, it veers to the left! Can someone explain this? 😊
Comments( 20 )
نايف عبد الناصر
نايف عبد الناصر2023-02-05 15:25
Adjust the steering angle.
سامر عبدالله
سامر عبدالله2023-02-01 08:05
I had the same issue. The tires got deformed, but swapping them solved the problem.
عبدالله ق
عبدالله ق2023-01-28 20:44
100% swing arm bolt loosening
عبدالرحمن هكيل
عبدالرحمن هكيل2022-11-25 21:45
First, check the tire pressure and inspect the tires for any damage, bulges, or uneven wear. Then, check the alignment data and use a computer to match the power steering unit.
خالد فواز
خالد فواز2022-11-21 19:52
Is the air pressure in the left tire a bit low? If the tire pressure is the same for all, I suggest you get a wheel alignment.
عبد العزيز حسن
عبد العزيز حسن2022-03-02 19:57
Toe alignment is off, better get a four-wheel alignment done.
عبد العزيز أيوب
عبد العزيز أيوب2022-02-08 20:51
That's normal, mine does the same. Just keep it running for a while and it should be fine.
عبدالله عمرو
عبدالله عمرو2022-01-03 11:28
Stop the car, turn off the engine, and try restarting it.
سلمان جم دين
سلمان جم دين2022-01-02 21:11
I've had my manual car for three years now, and occasionally the steering wheel pulls to the left a bit, but it fixes itself after a while. I went to the dealership, but they couldn't find anything.
عبدالرحمن بندر
عبدالرحمن بندر2022-01-02 20:53
The front left tire might have low pressure, right?
When I turn the steering wheel to the left, there's a strange noise like the brakes are being applied. It doesn't happen when driving at high speeds or when turning right, just goes "zhi, zhi!" Can any expert help explain this?
I want to ask, why is the front brake caliper of the Taycan positioned at the front? Isn't it said that for mid-to-high-end cars, the front wheel calipers are generally positioned at the rear? Please explain.
At the end of November, I replaced the control arm, steering rod, and axle assembly. Now the steering feels very light. When going over bumps, the steering wheel moves erratically. If I accelerate a bit aggressively, the steering veers off. Can someone help me out? [crying]
Do you have the issue where the steering wheel is straight, but the car veers to the left?
Does your car veer to the right when you let go of the steering wheel?
I bought the 2019 Bestune T99 in September 2020. Since it was my first car purchase, I lacked experience and fell into many traps. Besides having many minor issues, I later discovered several parts were damaged. The tires were previously used, which immediately made me suspect that this car was probably a test drive vehicle. And I was right. A few days ago, I went to replace the turn signal lights and found that the wiring inside had been reconnected, and the connections were poorly done. Moreover, the production dates of the left and right turn signals were almost a year apart. (Cars from the factory have uniform dates.) After all these years, it's impossible to explain this to the dealership now! I hope everyone pays attention to details when buying a car to avoid being deceived.
I have a question. For a 2017 Honda City with 90,000 kilometers, when I turn the steering wheel fully to the left while reversing, I hear a clicking sound. But when I turn it to the right, there's no sound, and there's no pulling to one side when driving on the highway. What could be the problem?
Has anyone done a wheel alignment? My City has uneven wear on the left rear tire and slightly pulls to one side. I've heard that the City’s rear wheels are non-adjustable and you can only add shims during alignment. Is this safe? Also, is it necessary to do a wheel alignment since the tires are quite cheap? 🤦‍♂️
I recently bought the 2024 Tiida Intelligent Edition and it's my third time driving on the highway. When I reached 130 km/h, I noticed that after exiting the highway, the steering wheel needs to be slightly turned to the right to go straight. If I keep it centered, the car veers to the left. Is this normal? Also, is getting a wheel alignment expensive?
Kia Pegas
Kia PegasOMR 4,200 ~ 5,764Gasoline & Petrol
