عمر عثمان
2022-12-28 06:25
Hey folks, have any of you experienced clutch master cylinder oil leaks? It seems like the leak is at the connection between the master cylinder and the oil pipe. Is this a common issue?
Comments( 6 )
خالد عبد الغفار
خالد عبد الغفار2023-01-27 01:03
No, in 2017 it ran 35,000 kilometers on construction sites with aggressive driving, and maintenance was done once a year with filter replacements.
عبدالله ماجد
عبدالله ماجد2023-01-24 20:27
Manual transmission common issues, free replacement by 4S, problems with both master and slave cylinders.
علي عفان
علي عفان2023-01-11 10:53
Buy a box of small pads and replace them as they leak.
محمد ناصر
محمد ناصر2023-01-09 23:14
My direct glue is dead.
عمر عثمان
عمر عثمان2023-01-07 15:06
Ah, this is a common issue. It leaks in winter, but it's fine in summer.
أحمد عين
أحمد عين2023-01-04 15:18
I had a leak too. Last year, I replaced the gasket at the 4S shop, and it stopped leaking. But now, less than a year later, it's leaking again. Not sure if it's a big deal or not.
Whenever I accelerate my Phaeton 3.6, there's a sound like metal clanking coming from the middle section of the exhaust pipe. I can't seem to fix it. I had it checked, and there's nothing wrong with the exhaust pipe. The dealership mentioned it's a common issue. Has anyone else experienced this problem? Any solutions?
Why is the clutch master cylinder of my Haval leaking oil after running less than 20,000 kilometers?
Does your engine cylinder head leak oil?
Pajero V93 chassis is leaking oil, and it's dripping onto the exhaust pipe. It needs repair.
Is it possible for there to be an oil leak at the connection between the transmission and the engine?
What could be the issue with the 2019 JETOUR X70 having difficulty shifting gears? The clutch master cylinder and transmission have already been replaced, and the issue has somewhat improved. However, sometimes it's still hard to engage first gear.
How many kilometers can the clutch slave cylinder of a manual Sunny typically last? Mine seems a bit off, but the gear shifting is all normal.
This pipe seems to be leaking oil. Does this happen to you as well? Also, what is the purpose of this pipe? Is it for exhaust gas recirculation?
Kia Kia Pegas
Kia PegasAED 50,000 ~ 55,000Gasoline
