Hey car enthusiasts, does your KIA Pegas have the rear end wiggle when going over speed bumps or uneven roads while turning? My car is pretty stable at 120 on the highway, but when taking a turn and encountering such conditions, the rear seems to wiggle a bit. I've done the wheel alignment, but it doesn't seem to help.
Can a wheel alignment be done if the rear tires of a 2015 Sportage are wearing unevenly?
I have a 2012 Jeep Compass. Recently, when I turn on the AC, there's a clicking sound coming from the glove box area, but it stops after a few clicks. Also, when I'm turning at low speeds, it feels like the rear wheels are stuck, causing the car to vibrate and the rear wheels seem to be rubbing or bouncing on the ground. Has anyone experienced similar issues?
Has anyone experienced the same issue with the 2016 Jeep Renegade? When driving at speeds of 60-80 km/h over manhole covers or bumpy roads, the rear end feels loose (swaying side to side). The car hasn't been in any accidents, the rubber bushings seem fine, and the wheel alignment data is normal.
4Hey guys, my Land Cruiser tends to pull the steering wheel when driving on bumpy roads, and it doesn't feel very stable. I've already done a wheel alignment, and the mechanic said there's nothing wrong. Is the steering wheel pulling a normal phenomenon?
5Hey car enthusiasts, does your KIA Pegas have the rear end wiggle when going over speed bumps or uneven roads while turning? My car is pretty stable at 120 on the highway, but when taking a turn and encountering such conditions, the rear seems to wiggle a bit. I've done the wheel alignment, but it doesn't seem to help.
6After replacing the front suspension arms on my 2014 compact car, the steering wheel feels much lighter and not as stable as before. I took it to a repair shop, and they changed the valve core, saying it was a tire pressure issue. However, the light steering feel returned shortly after. I've already done wheel alignment and balancing, but haven't changed the power steering fluid. What could be the reason for this?
7What could be the problem with the 86? When I make a slightly sharp left turn, the traction control activates, even though the ground is dry and there's no rain. It doesn't happen on right turns, and the car isn't skidding; I'm maintaining a steady speed. I've been to the mechanic, but they couldn't find the issue, and I've also done a wheel alignment. [Crying][Crying]
8Does this car have rear fog lights? I bought it second-hand, and it seems like nothing changes when I turn on the rear lights.
9My Kodiaq's rear inner tires are wearing unevenly and noticeably. The repair shop says the lower arm needs to be replaced because it's not an adjustable one, so four-wheel alignment can't be done. Does anyone know if this is correct?
10Has anyone done a wheel alignment? My City has uneven wear on the left rear tire and slightly pulls to one side. I've heard that the City’s rear wheels are non-adjustable and you can only add shims during alignment. Is this safe? Also, is it necessary to do a wheel alignment since the tires are quite cheap? 🤦♂️
