محمد فرج
2021-03-17 01:45
Has anyone modified the LED headlights on a Kia Pegas? I'm thinking of replacing them because the halogen lights don't seem bright enough.
أحمد نظيف
أحمد نظيف2021-04-07 08:23
It can be modified later.
نايف تاج
نايف تاج2021-03-21 13:10
It can be modified.
علي صادق
علي صادق2021-03-17 15:12
Whether to change it or not, it doesn't really matter.
علي حسن
علي حسن2021-03-17 06:18
If you directly switch to LED headlights, the effect will be slightly better than halogen lights. However, because there's no lens, its focus isn't great. So, it's recommended to add a lens for a significant improvement. Generally, upgrading to a full LED headlight assembly costs around 2000 RMB.
I feel like the headlights aren't bright enough, especially the high beams. Do any fellow car enthusiasts know of any parts I can replace them with?
Hi everyone, I'm looking to upgrade the halogen headlights on my 2014 Yizhi to LED ones because they're not bright enough. Any good recommendations? Thanks!
Does anyone feel that the headlights of the Yaris X are not bright enough? Has anyone modified the headlights, and are there any compatible headlights available now?
Which type of LED light is better for the Kia Pegas, and which brand? I've tried several LEDs but none seem to provide a good result.
Hey guys, how's the LED upgrade for the 2019 luxury halogen headlights? Anyone who has done it, please share your experience. I'm really torn about this. Thanks!
Hey folks, are your car lights bright enough? I'm thinking about changing mine because they don't seem bright, but it looks like I have to remove the entire headlight to do it. Has anyone done this before? Any advice?
I bought a used 2018 Peugeot 3008 and feel like the halogen lights aren't bright enough. I replaced them with LED bulbs, but the light is still scattered and not good. Could you suggest what bulbs I should use? Also, does the original car come with projector lenses?
The original halogen headlights on the Sharan were replaced with LED headlights, and they flicker during start-stop. Should I use 5054 to activate the xenon mode for the low beam to stop the flickering?
Can the daytime running lights be replaced separately? I modified the headlights, and it seems like the daytime running lights got damaged; their brightness isn't enough. It's a 2009 model.
The headlights on the Murano have a high wattage, but they don't seem very bright.
Kia Kia Pegas
Kia PegasAED 50,000 ~ 55,000Gasoline
