عبدالرحمن يونس
2023-03-12 20:11
Do you hear a sound like two wires colliding under the front left side of the dashboard when driving your Hyundai Reina on bumpy roads? It seems to be related to the steering gear. I've checked the chassis multiple times but couldn't find the issue. Have any of you experienced this problem?
سعود ماجد
سعود ماجد2023-03-17 21:21
It might be the sound of wires vibrating behind the USB and cigarette lighter panel. In my car, when I press the accelerator and the engine reaches around 1500 RPM, a faint "dada" sound comes from behind the center console. During maintenance, I asked the 4S shop to check it. The technician removed the USB and cigarette lighter panel and pulled the connected wires tighter, and sure enough, the noise disappeared.
The cigarette lighter fuse for the 1819 model of Yuxiang is located in the fuse box. You can usually find the fuse box under the dashboard on the driver's side or in the engine compartment. Please refer to the vehicle's manual for the exact location and diagram of the fuse box.
After your ASX is turned off, can you hear a clicking sound from the air conditioning vents on the dashboard after about a minute?
Hey car enthusiasts, after parking and turning off the engine, without opening the door, I can hear a loud electric current noise from the dashboard/center console. Have any of you experienced this?
Is there anyone experienced with installing a 360-degree camera? Could you please tell me where to find the turn signal wire? I've been looking under the driver's side and can't find it. 🤣
I have a 2017 V60, and sometimes I hear a clicking noise from the chassis when driving at high speeds. The noise disappears if I lightly tap the brakes. I suspect it might be an issue with the brake system, but I've been to the dealership twice and they couldn't solve it. Has anyone experienced a similar problem? Any solutions would be greatly appreciated!
Hey guys, have you ever had your phone get super hot when left on the dashboard under the sun? Any tips on how to fix this?
I just got my G70. How did everyone install their dash cams? Did you run the wires through the A-pillar and then route them under the center console to connect to the cigarette lighter?
To check the fuse for the front left low beam on a Skoda, you should first refer to your vehicle's owner's manual. The manual typically contains a diagram showing the location of the fuse box and details about each fuse. In most Skoda models, the fuse box is usually located either under the dashboard on the driver's side or in the engine compartment. Once you locate the fuse box, look for the diagram that indicates which fuse corresponds to the low beam lights. Make sure to replace any blown fuse with one of the same amperage.
Hey fellow Grand Cherokee owners, when I start my car in the morning, I hear a "clattering" sound from under the chassis, but it goes away after starting. What could be the reason for this?
Kia Kia Pegas
Kia PegasAED 50,000 ~ 55,000Gasoline
