سعود نايف
2023-12-10 09:41
Do you have any tips for fixing a car door handle that sometimes doesn't return to its original position after being pulled?
Has anyone set up the key recognition feature? After I set up this feature, the seat doesn't return to the position it was in when I last got out of the car. What should I do?
My March's right mirror isn't folding back automatically. It can fold out but not return to its original position. What should I do?
I bought a Kia Sportage in 2010, and suddenly the right rear door won't open. What could be the reason? It's not the child lock issue. Also, the door handle feels loose when pulled.
When the suspension is raised to its highest level, after parking and turning off the engine, the vehicle sometimes lowers to a normal height. I haven't activated the easy entry/exit feature, and it doesn't lower immediately after turning off the engine. Sometimes it doesn't lower at all, while other times it lowers on its own.
Hi everyone, I need some advice. The middle doors on my T6 keep having issues. Sometimes they automatically open or close halfway and then suddenly bounce back. Other times the button doesn't work at all, and the door button flashes a fault. Sometimes I have to press the button twice, holding it down on the second press until the door fully opens or closes before I can release it. What could be the problem, and how should I fix it? Please help.
Where can I get a clutch that doesn't return fixed?
Hey guys, I'm having an issue with my car's driver door. Sometimes I can't open it from the inside. I have to use one hand to pull and the other hand to pull the door latch to open it. Plus, there's a clicking sound when I pull the latch. Any idea what's wrong?
How to fix the issue of the gear position light not illuminating sometimes for the '21 model Compass when in Reverse (R) gear?
Is it a problem with the ignition switch if the Volvo S40 key is turned to the second position, but there's no power and it reports an engine anti-theft system fault? I changed the ignition switch, and now it's sometimes good and sometimes bad. Sometimes the dashboard lights up, sometimes it doesn't, and sometimes it even starts automatically.
Kia Kia Pegas
Kia PegasAED 50,000 ~ 55,000Gasoline
