نايف جلال الدين
Oct 17
Do I need to change the transmission oil for my 2020 automatic Kia Pegas that has only run 20,000 kilometers? Fellow car owners, at what mileage do you all change your transmission oil?
Hi fellow car enthusiasts 😄, do you know where the external transmission filter is on this car? Couldn't find it when changing the transmission oil. Thanks 🙏🙏
My manual Kia Pegas has run over 20,000 kilometers. This afternoon, the malfunction indicator light kept coming on. I turned off the car and restarted it, but the light is still on. Seeking advice from fellow car enthusiasts.
How many kilometers should the Kia Pegas drive before changing the belt?
4Do I need to follow the dealership's requirements for the 2020 model with 40,000 km? Transmission oil?
5Which brand is better for changing the transmission oil of the 2020 Haval H6?
6How do you guys change the transmission oil, gravity or circulation?
7Do I need to remove the oil pan to change the transmission oil for the 2019 GAC GA5?
8Does the Eclipse Cross need a transmission oil change after 20,000 kilometers and four years? Thanks.
9Any recommendations for which brand and type of engine oil to use for a 2019 Kia Pegas that's run about 65,000 kilometers, as a second-hand car?
10When did you all change your transmission oil, and at how many kilometers?
