The difference between canceling cruise control and turning off cruise control in a Patrol is essentially about how the system is deactivated. Canceling cruise control is a temporary deactivation, allowing you to resume the set speed later, while turning off cruise control completely deactivates the system until you set it up again.
Can the GS7 be set to automatically engage the handbrake when the engine is turned off? Has anyone set it up before?
How do I turn off the 360 panoramic image that pops up on the central control when turning?
To activate the cruise control on the MX-5 NC, first make sure you're driving at your desired speed. Then, locate the cruise control button on your steering wheel or stalk and press it to turn on the system. Once activated, you should see a cruise control indicator light on your dashboard. Adjust the speed using the "Set" or "Resume" buttons as needed.
4Why can't the cruise control on the LC300 be activated? It shows OFF and won't turn on no matter what I do.
5Is there in-car monitoring that allows remote viewing on a phone when the car is parked and turned off?
6The difference between canceling cruise control and turning off cruise control in a Patrol is essentially about how the system is deactivated. Canceling cruise control is a temporary deactivation, allowing you to resume the set speed later, while turning off cruise control completely deactivates the system until you set it up again.
7The difference between the "Cancel Cruise" and "Turn Off Cruise" buttons on the steering wheel of a Patrol is as follows: - **Cancel Cruise**: This button temporarily deactivates the cruise control while keeping the set speed in memory. You can resume the cruise control to the previously set speed later without having to set it again. - **Turn Off Cruise**: This button completely deactivates the cruise control system and clears the set speed from memory. To use cruise control again, you would need to set the speed anew.
8After the central control was reset to factory settings, it shows that it can't connect to the network and can't enter the system.
9The issue with the cruise control not holding could be due to several reasons. While the indicator light on the dashboard shows that the cruise control is activated, it might not maintain the set speed.
10To turn on the heater without the AC light coming on, you usually need to adjust the settings on your car's climate control system. Make sure that the AC button is turned off. If your car has an automatic climate control system, try switching to manual mode and adjusting the temperature and fan settings manually. If the AC light still comes on when you activate the heater, it might be due to the car's design to dehumidify the air, in which case you may need to consult your vehicle's manual or contact a service center for further assistance.
