عبدالرحمن فايز
2024-06-12 21:39
I just got the Middle East 5.6, and I noticed that in daily use, the car mostly runs at idle speed, not even reaching 1500 RPM at 100 km/h. Will long-term low RPM driving lead to carbon buildup? I need advice from experienced experts.
علي هشام
علي هشام2024-08-06 07:10
Don't worry, just go with the flow. Car manufacturers are not naive; they've already thought of everything. [I want to be alone] Cars are meant to serve people; they're just a means of transportation. [Grin]
Where can I find a shop or parts to convert a 2012 Middle East version of the Previa to have electric sliding doors?
I have a 2021 2.0F1A manual Euro Victory, and when I shift from 2nd to 3rd to 4th gear and accelerate, there's a clicking sound between 1100 and 1400 RPM, like it's low on oil. Does anyone else experience this? Once the RPM reaches around 1500 and the turbo kicks in, the sound starts to decrease. The 4S shop upgraded the ECU, but the sound is still there, whether the AC is on or off.
Guys, for the Middle East version of the '16, can this footboard be repaired? It's just the outer plastic that's slightly damaged. I don't want to replace the whole footboard.
What should I do if there's carbon buildup?
When I start the car, the idle speed is around 2000 RPM, but after a while, it drops to 1500 RPM. It takes quite a long time to go down to around 1000 RPM. Does anyone know what's going on?
Where can I buy the original wiring harness for the 2018 Nissan Patrol Middle East version?
Has anyone experienced repeated jerking at a certain RPM (mine is at 1500-1600)? Lightly pressing the accelerator to maintain this RPM causes repeated jerking, but it stops if I accelerate more or release the pedal. This issue has randomly appeared several times and then mysteriously resolved itself.
Does the 2021 Murano have a buzzing resonance at 1500 RPM? Should I go to the dealership to request a replacement of the exhaust manifold and bracket? Will not replacing the exhaust manifold cause it to crack?
My Zhilong 2022 model 2.0 has reached 20,000 kilometers. When the engine is cold-started, there's a "dang dang dang" sound at 1500 RPM, but it's gone at 800 RPM. Is it the same for you guys?
Nissan Nissan Patrol
Nissan PatrolAED 194,000 ~ 398,500Gasoline & Gasoline & Petrol
