عبدالرحمن ممدوح
2024-01-03 09:29
Hello fellow car enthusiasts, I own a Patrol Y62. A few days ago, while driving, the lower ball joint on the left rear wheel suddenly broke. Do you know what might have caused this?
فهد مك
فهد مك2024-01-11 00:08
The ball joint is worn out.
The transmission light on your car suddenly turned on for a few minutes and then went off. Sometimes it lights up while driving, but it hasn't come on in the past few days. What could be the reason?
Just got the car 2 days ago. When I picked it up, it showed 435, but it seems like I've only driven less than 300, with a bit over 90 left, so I went to charge it. Is this normal for city driving?
My relative gave me a 2006 Peugeot automatic 1.6L 307. A few days ago, it was running low on fuel (almost to the red line), and the range showed there were 60km left. Suddenly, it made a "ka" sound and everything stopped, showing something about "gearbox." After turning it off and restarting, it was fine, and adding fuel prevented the issue from happening again. Should I get it checked? The mileage was over 60,000 when I got it, and now it's at 88,000. Seeking advice from the forum experts.
I have a 2017 Haima S5 manual 1.5T, and I'm facing some issues: the car door is rusted through, there's a noise from the chassis (note: I've replaced the lower control arm, ball joint, steering gear, and engine mount but still can't find the problem), and the USB port inside the car has poor connection. Is there anyone experiencing the same issues? Any solutions?
I bought a used 2007 Kia Sportage with a V6 2.7 engine a few days ago. What type of engine oil should I use? Any advice, experts?
Is it troublesome to replace the shock absorbers on a Mazda 6? I noticed during maintenance a few days ago that both the front and rear shock absorbers are starting to leak oil.
A few days ago, I mistook a Porsche for a Xiaomi on the street. So embarrassing!
Hello everyone! I have a 2022 Pioneer Edition Toyota Asia Lion, and I recently installed ambient lights. A few days later, the car battery died. Does anyone have a good solution for this issue?
Nissan Nissan Patrol
Nissan PatrolAED 194,000 ~ 398,500Gasoline & Gasoline & Petrol
