حسين عبد له
2023-05-31 09:02
When I turn on the AC, it makes a noise... After a while, it gets a bit better, but when I stop the car, it starts making noise again... Has anyone experienced this? Thanks.
عمر شخبوط
عمر شخبوط2023-05-31 22:17
Just replace the air conditioning flap motor.
Why does the 2020 Subaru Legacy make a sputtering noise when it is about to stop and just starting up?
Hey folks, I need some advice. When I start the car and turn on the AC, there's this really bad smell at first, but it goes away after a bit. How can I fix this? Thanks!
Is there anyone with a Levante experiencing a ticking noise when idling after warming up the car? The noise disappears when you press the accelerator a bit. What could that sound be?
I need some help. I have a 2019 MG HS 1.5T, and it's run for 37,000 kilometers. The engine pulley makes a squeaking noise when I release the accelerator, and it also makes noise when I turn on the AC. What should I do? I just replaced the alternator pulley, but it didn't help.
Changan CS35 Plus makes a strange noise when turning the steering wheel while stationary.
Hello fellow car enthusiasts, I have a 2013 VW Jetta manual comfort model. After running the AC for about an hour, the airflow becomes weak and almost stops. If I pull over, turn off the AC for a while, it goes back to normal. Has anyone else experienced this issue?
When you enter the GV80 and the driver's seat adjusts automatically, does the buzzing sound continue for a while after it stops moving? Has anyone else experienced this? Thanks.
Have you ever experienced the driver's door interior panel making a squeaking noise intermittently while driving? What could be the reason for this?
Hi everyone, I need some advice. I have a 2016 Nissan X-Trail with 70,000 km on it. The AC blows cold air for about 10 minutes, but then the airflow decreases. If I turn off the AC for a while and then turn it back on, it works fine again, but after a few minutes, the airflow decreases once more. Alternatively, if I turn off the AC, the airflow increases, and when I turn the AC back on, it runs normally, but after about 10 minutes, the issue returns. What could be the problem? Thanks!
