To distinguish between a 2013 and 2014 Jeep Compass, you can look for specific features and changes that occurred between the two model years. Since your VIN indicates it's a 2014 model, but it was purchased in December 2013, it's likely a 2014 model. One way to check the transmission type is to look at the gear shifter or check the owner's manual. The 2014 model might have different features or updates compared to the 2013 model, such as changes in the interior or technology features. If you’re still unsure, you could consult a dealership with your VIN for confirmation.
I want to ask how to distinguish between the S80 and S80L? It's an 08 model. The owner says it's an S80L, but I checked and couldn't find an S80L for the 08 model, only an S80. Can any expert explain this? Thanks a lot 🙏
How do you distinguish between the 451 and 453 models, AMT and dual-clutch transmission?
How to distinguish if the Compass is CVT or AT? Checking the VIN shows different results, some show CVT and some show AT. Seeking help from everyone.
4You have a 2016 model with a CVT transmission, but you're not sure which version it is. You can usually find this information in a few places: 1. **Owner's Manual**: The manual that came with the car often lists the specific version or trim level. 2. **VIN Number**: Locate the Vehicle Identification Number (VIN) on your car and use it to check online databases or contact the manufacturer for detailed information about your car. 3. **Door Jamb Sticker**: There is often a sticker in the driver's side door jamb that includes details about the vehicle, sometimes including the model version. 4. **Service Records**: Check any service or maintenance records you have for your vehicle, as they might list the specific model version. 5. **Dealership**: Contact a dealership with your VIN number, and they can usually provide detailed information about your car.
5Looking to buy a 2014 ChuanKao with outward opening doors, model years between 19-23 are acceptable.
6To determine whether your Jeep Compass is equipped with an AT (Automatic Transmission) or CVT (Continuously Variable Transmission), you can check the following: 1. **Owner's Manual**: Refer to your vehicle's owner's manual, which should specify the type of transmission. 2. **Vehicle Documentation**: Check any official documents related to the vehicle, such as the purchase agreement or service records, which might indicate the transmission type. 3. **Under the Hood**: Look at the transmission system under the hood. Sometimes the transmission type is labeled on the transmission unit itself. 4. **Vehicle Identification Number (VIN)**: Use the VIN to decode the specifications of your vehicle. Websites or services that provide detailed vehicle information based on VIN can help you identify the transmission type. 5. **Contact Dealership**: Reach out to a Jeep dealership with your VIN. They should be able to provide you with detailed information about your vehicle's transmission type. If there is conflicting information from different sources, the dealership is likely your most reliable source.
7How to distinguish between luxury and comfort models?
8To distinguish between a 2013 and 2014 Jeep Compass, you can look for specific features and changes that occurred between the two model years. Since your VIN indicates it's a 2014 model, but it was purchased in December 2013, it's likely a 2014 model. One way to check the transmission type is to look at the gear shifter or check the owner's manual. The 2014 model might have different features or updates compared to the 2013 model, such as changes in the interior or technology features. If you’re still unsure, you could consult a dealership with your VIN for confirmation.
9Does anyone know the difference between the 2011 and 2013 models?
10Is the manual Alto manufactured in May 2014 a 2013 model or a 2015 model?
