The second key hasn't been used for a while. Recently, I took it out and found that the remote doesn't work. I changed the battery, but it still doesn't work. Does anyone know why?
It seems like your 2011 Phaeton is experiencing some issues with the remote unlocking and the keyless start system. Sometimes you have to use the mechanical key to lock and unlock the car, and the keyless start doesn't work. Occasionally, after using the mechanical key to start and then turning off the engine, the remote unlocking and keyless start work fine again. What could be the problem?
I recently found out about this car and really like it, but the dealership in my area doesn't have it anymore. They said it's been discontinued and replaced by the Haval Jolion. I'm not sure if it's really no longer available.
4It seems like the car key is out of battery, and the car won't start.
5Is there any other way to open a Volvo S40 if the remote doesn't work? Thanks.
6The remote key is locked! The car doesn't lock! What's the issue?
7My car was parked for a while, and I disconnected the battery. Now that I've reconnected it, the loudspeaker keeps sounding continuously, and the remote key isn't working. Does anyone know what's going on?
8The car is over three years old, and recently the key isn't working well. Could it be that the battery is dead?
9Does your key run out of battery every two years?
10Hey car enthusiasts, does the rear trunk of the Seltos luxury edition have a remote control function? I see a trunk remote icon on the key fob, but it doesn't work. Thanks!
