عبدالرحمن فايز
2023-07-08 13:38
The car wouldn't start just now, and the screen didn't light up. I couldn't unlock it with the key fob either, so I had to manually turn the car door open with the key.
جعفر خالد
جعفر خالد2023-07-10 16:17
The battery is dead.
I disassembled the Peugeot 301 key and moved the chip to a new case, with the metal key separate. Now, the remote can unlock the door, but the metal key won't start the car. Could it be the key issue that's causing the car not to start?
How do you unlock the child lock on the 19zs rear door? It's annoying that the door can only be opened from the outside.
The keyless entry function on the GS 5 is not working properly. Approaching the vehicle no longer locks or unlocks it, and the function is unresponsive. The key fob's battery was just replaced. What's going on here?
What could be the reason that when I press the key, the car doesn't respond and the doors won't open?
Hey car enthusiasts, have you ever experienced the trunk opening when you press the car key to unlock or lock the car? The sensor works fine for opening and locking the doors! But when I use the key to press the trunk button, it opens. What's going on??
Why does the driver's door not open with the key unlock button after locking the car from the outside, while the other three doors can be opened?
2014 Peugeot 2008 manual transmission, the remote key can't unlock the driver's door (can open with the key), while the other three doors work fine. Any advice on how to solve this issue? 🙏🙏🙏
The car hasn't been driven for just two days, and the door can't be unlocked. I used the mechanical key to open the door, but there's no power at all inside. What's going on?
The car often reports that it can't detect the key as soon as I open the door... The key is a replacement. What's going on?
