خالد عادل
2024-06-29 05:08
Jeep Liberty, 2012 model with over 170,000 km. It often stalls, especially when reversing with the AC on. When waiting at a red light with the brakes fully pressed and the AC on, it occasionally stalls too. I can't read any error codes. Does anyone know what might be the issue? Could it be a compression problem?
محمد ابيض
محمد ابيض2024-07-13 08:48
There was an unknown stalling issue before, couldn't find any fault codes. Replaced the sensor, cost over 500, and it got fixed.
نظيف عبدالله
نظيف عبدالله2024-07-05 00:02
When I first start the car and reverse, I've experienced stalling. After driving for a while and then reversing, it doesn't happen. I think it's because the engine is cold when first started, the idle speed is high, and the load is heavy. Plus, reversing generally requires more horsepower than moving forward, which might cause stalling. If you turn on the air conditioning, I'm not sure about the car's condition. Just sharing my experience for reference!
The third-generation Haval H6 MAX occasionally has a noticeable jerk or thump when starting at a red light. Does anyone have any solutions to fix this?
When I put it in drive, the engine stalls. I have a 2017 model 95 with over 70,000 kilometers now. Recently, I've encountered a problem where the engine stalls when I put it in drive while waiting at a red light. It's happened a few times already, but the 4S shop couldn't find the issue. Has any fellow car owner experienced this problem?
Why does the start-stop function in the 2009 Smart cause the vehicle to stall? It usually happens when waiting at a red light. When the start-stop function is on and the light turns green, I find that the vehicle has already stalled, and I have to wait a moment before I can restart the vehicle.
Occasionally, the vehicle loses gears while driving, but after restarting, it returns to normal. The repair shop couldn't read any error codes and initially suspects the mechatronic unit might be the issue. Are there any other owners with the same problem? How did you resolve it? Thanks 🙏
Is it a problem if my GAC GS5 occasionally shows error codes? How can I fix it?
When the air conditioning is on and blowing cold, the car shakes a lot, especially when stopped at a red light. It's uncomfortable. Do any of you have this issue with your car?
In the morning, when starting the vehicle and driving at low speeds, it occasionally stalls. I've already cleaned the throttle and injectors, but it still stalls sometimes. If the speed picks up, it doesn't stall. What could be the reason? 🤦‍♂️
I have a Haima S5 with an automatic transmission, and occasionally the transmission warning light turns on. But when I press the brake, it goes off! When I try to read the error code, nothing shows up. What could be the reason?
