It's a common issue. The big smell in your car during summer is usually due to the heat causing materials inside to release odors. When you turn on the air conditioning, it helps circulate air and reduce the smell.
The message "Reduced Engine Performance" on your car usually indicates there's a problem that needs attention. This could be due to several reasons, such as issues with the fuel system, air intake, or engine sensors. The fact that the car stalls at low speeds suggests it might be a problem affecting the engine's idle function or fuel delivery. It would be best to have it diagnosed by a professional to pinpoint the exact cause.
If the external circulation of your car's air conditioning system can't switch to internal circulation, it might be due to a problem with the actuator or a control switch. The cost for repair can vary depending on the make and model of the car and the specific issue. I recommend consulting a local mechanic for an accurate diagnosis and cost estimate.
4I want to ask the experts, why does the air conditioning not work when I turn on the internal circulation? The light comes on briefly and then goes off, but the heating works fine. Why is that?
52021 Outlander Vehicle Odor Issue. Background: Recently, the car was parked in an underground garage for a month, and the garage was somewhat damp. Situation: An unpleasant odor, like a musty and rotten smell, has started to accumulate inside the car. Self-assessment: I've checked the interior but couldn't find the source of the smell. I also replaced the air conditioning filter, and the air blowing out doesn't have any odor. However, as soon as the car is parked for half a day and I get back in, there is a strong smell in the cabin. The car has never been submerged in water or flooded before. Question: Has anyone experienced a similar issue and can provide some guidance on how to deal with this?
6When you open the fuel cap of your 2014 ASX and hear a sound of air being sucked in, it could be due to the pressure difference between the inside of the fuel tank and the outside air. This is usually normal and can happen because the fuel system is sealed to prevent fuel vapors from escaping. If the sound is frequent or you're experiencing other issues, it might be a good idea to have it checked by a professional.
7To turn on the heater without the AC light coming on, you usually need to adjust the settings on your car's climate control system. Make sure that the AC button is turned off. If your car has an automatic climate control system, try switching to manual mode and adjusting the temperature and fan settings manually. If the AC light still comes on when you activate the heater, it might be due to the car's design to dehumidify the air, in which case you may need to consult your vehicle's manual or contact a service center for further assistance.
