علي أمير
2022-11-28 00:41
Is there a clunking noise from the front left when driving on bumpy roads? Has anyone experienced this issue?
سلمان انهايان
سلمان انهايان2022-12-09 17:35
Ball joints, tie rods, and suspension bushings need to be replaced or repaired.
عبدالرحمن حمد
عبدالرحمن حمد2022-11-30 09:50
The shock absorber needs to be replaced.
Has anyone experienced a rattling noise from the front of an '08 Mazda 5 when driving on bumpy roads? I've just replaced the front shock absorber assembly, lower control arm, tie rod end, sway bar link, and stabilizer bar bushing, but the noise persists. Any ideas?
When driving over slightly rough roads, there's a clanking noise from under the front wheels, like metal hitting metal. Has anyone else experienced this?
Is there any fellow Haval owner experiencing a clunking noise from the front right shock absorber when driving on rough roads?
When driving over bumpy roads, there's a suspected noise coming from the chassis around the rear axle area (a creaking sound). I want to ask if anyone else is experiencing this too?
Has anyone in the group experienced this issue with a 2019 Patrol, 4.0 Middle East version, after 70,000 km? When switching between D and R gears, there's a noticeable clunk from the chassis. It drives fine on the road, but when changing from forward to reverse, there's a distinct clunking sound.
Taurus chassis noise I have a 2019 Taurus, bought in 2021, and it's now at 57,000 kilometers. Recently, there's been a serious noise coming from the chassis, and it gets worse as the weather gets hotter. When the vehicle goes over speed bumps or when the front wheels hit uneven road surfaces at different times, there's a squeaky sound from underneath, like metal rotating inside a rubber bushing. When entering the garage and turning the steering wheel left, there's a clunk noise from the front when the front wheels hit a speed bump. The same clunk noise happens when parking with the steering wheel fully turned while reversing. The noise is very uncomfortable. Any suggestions from fellow car enthusiasts? Has anyone else experienced this?
What could be causing a clunking noise from the left front wheel on a 2013 Peugeot 508 2.3 while driving?
Hi everyone, I have a rattling noise on the roof. It doesn't make a sound on asphalt roads, but on bumpy roads, it keeps rattling. Has anyone experienced noise from the roof and how did you solve it?
Is there anyone who has experienced rattling noises from the center console screen and the driver's side door when driving on uneven roads in the 2019 Taurus? It's driving me crazy!
