I have a 2012 Jeep Compass. Recently, when I turn on the AC, there's a clicking sound coming from the glove box area, but it stops after a few clicks. Also, when I'm turning at low speeds, it feels like the rear wheels are stuck, causing the car to vibrate and the rear wheels seem to be rubbing or bouncing on the ground. Has anyone experienced similar issues?
Is there anyone else whose car makes a slight plastic rubbing sound when turning the wheel to the left?
Do the rear wheels turn when this car is self-parking?
4Nissan Patrol, 98k kilometers. Now when I turn the steering wheel all the way, it gets stuck, and I can't turn it. Also, when reversing, it doesn't move. Has anyone else experienced this issue?
5Chery Arrizo 3, sometimes there's a noise above the glove box. When driving, it usually stops, but after turning off the engine, closing the car door might cause the noise again. There's also a similar sound inside the passenger side B-pillar seatbelt. I want to take apart the dashboard to see if something is loose inside, but I'm not sure where to start. I've previously removed the bumper to install a loudspeaker and added a central control screen with a rearview camera. But I'm not sure how to start with the area above the glove box.
6When I turn the steering wheel of my MG ZS, I hear a clicking noise and feel vibrations under my feet. What could be the cause of this?
7I've had my KAMIQ for 1.5 years, and there's a clicking noise when I turn the steering wheel to the right, but not when I turn it to the left. The dealership can't figure out the cause... Anyone else experiencing the same issue?
8When turning the steering wheel of the MG HS, there's a clicking sound on the left side.
9When I turn on the AC in my 2019 Taurus, the rear vents blow hot air. What could be the reason for this? Can anyone help explain?
10Hey guys, the AC isn't cooling and is blowing hot air. When I turn on the AC, the compressor doesn't work, even though it's new. The repair shop said the fuse box has a bad connection and replacing it would cost over a thousand. What should I do?
