I got a Jeep Compass from September 2012, but it shows as a 2013 model. Can anyone tell me if this car has a tire pressure monitoring system? If it does, I'll get some original sensors to install.
The original 17 model Jeep Compass doesn't have CarPlay. I'm looking to replace it with a big screen that includes these features. Does anyone have recommendations, or can the original screen from the 19 model Compass be compatible? 🙏🙏🙏🙏
Does the 2012 Jeep Compass with a 2.4 engine consume oil or lose oil?
To distinguish between a 2013 and 2014 Jeep Compass, you can look for specific features and changes that occurred between the two model years. Since your VIN indicates it's a 2014 model, but it was purchased in December 2013, it's likely a 2014 model. One way to check the transmission type is to look at the gear shifter or check the owner's manual. The 2014 model might have different features or updates compared to the 2013 model, such as changes in the interior or technology features. If you’re still unsure, you could consult a dealership with your VIN for confirmation.
4I got a Jeep Compass from September 2012, but it shows as a 2013 model. Can anyone tell me if this car has a tire pressure monitoring system? If it does, I'll get some original sensors to install.
5I just got a 2013 model with a 1.4t engine, and it's been driven for 130,000 kilometers. When I use lower-grade fuel, the high-pressure fuel pump makes a buzzing sound. What could be the reason for this, experts? The sound goes away after driving for a while, but it happens right after starting the car.
6The tire pressure monitoring sensor is broken.
7To reset the tire pressure light on the MG GS 4WD, follow these steps: 1. **Check Tire Pressure**: Ensure all tires are inflated to the recommended pressure levels. You can usually find the recommended pressure on a sticker inside the driver's door or in the owner's manual. 2. **Drive the Car**: Sometimes, simply driving the car for a few miles can reset the tire pressure monitoring system (TPMS) if the tires are properly inflated. 3. **TPMS Reset Button**: Some models may have a TPMS reset button. Check your vehicle's manual for its location and instructions on how to use it. 4. **Professional Assistance**: If the light remains on, it might be necessary to have the system checked by a professional, as there could be an issue with the TPMS sensors. Please follow these instructions based on your specific vehicle model and refer to your owner's manual for more detailed guidance.
8Hello everyone, I recently got a 2020 Jeep Compass 1.3T. Can anyone tell me how to turn on the daytime running lights?
9Hi everyone, I'm considering buying a Jeep Compass around 14.15. I'll use it for daily commuting. Is the only difference between the 2.0 and 2.4 models the two-wheel drive and four-wheel drive? Which one would be more suitable for me?
10Should I replace the oil pressure sensor on a 2017 1.4T Sharan? Is the original sensor an improved version?
