حسن هادي
2023-02-12 17:08
How to distinguish if the Compass is CVT or AT? Checking the VIN shows different results, some show CVT and some show AT. Seeking help from everyone.
سعود إدريسي
سعود إدريسي2023-02-15 22:32
In 2013, I can't remember which month, but after that, all 2.4 models were AT, and before that, they were all CVT.
عبدالرحمن أنور
عبدالرحمن أنور2023-02-15 22:08
I just saw something on Baidu Tieba and I'm not sure if it's correct. Looking at the dashboard, blue for CVT, white for AT.
Hey everyone, I need some help with my Peugeot 206! Thanks a lot in advance! 1: Is the 2007 model with a 1.6L manual engine Euro 2 or Euro 3? 2: How can you tell the difference between the high-end and low-end versions of this car? 3: Why are some interiors white and others black? 4: Why are the instrument panel colors different?
To determine whether your Jeep Compass is equipped with an AT (Automatic Transmission) or CVT (Continuously Variable Transmission), you can check the following: 1. **Owner's Manual**: Refer to your vehicle's owner's manual, which should specify the type of transmission. 2. **Vehicle Documentation**: Check any official documents related to the vehicle, such as the purchase agreement or service records, which might indicate the transmission type. 3. **Under the Hood**: Look at the transmission system under the hood. Sometimes the transmission type is labeled on the transmission unit itself. 4. **Vehicle Identification Number (VIN)**: Use the VIN to decode the specifications of your vehicle. Websites or services that provide detailed vehicle information based on VIN can help you identify the transmission type. 5. **Contact Dealership**: Reach out to a Jeep dealership with your VIN. They should be able to provide you with detailed information about your vehicle's transmission type. If there is conflicting information from different sources, the dealership is likely your most reliable source.
To distinguish between a 2013 and 2014 Jeep Compass, you can look for specific features and changes that occurred between the two model years. Since your VIN indicates it's a 2014 model, but it was purchased in December 2013, it's likely a 2014 model. One way to check the transmission type is to look at the gear shifter or check the owner's manual. The 2014 model might have different features or updates compared to the 2013 model, such as changes in the interior or technology features. If you’re still unsure, you could consult a dealership with your VIN for confirmation.
I got a Jeep Compass from September 2012, but it shows as a 2013 model. Can anyone tell me if this car has a tire pressure monitoring system? If it does, I'll get some original sensors to install.
The 2014 Jeep Compass with a 2WD CVT transmission is great in many aspects, but I'm worried about the starting issue. If the RPM is too low, the car doesn't move, and if it's too high, it might damage the transmission. [Covering face] I'm concerned that this could cause problems during vehicle inspection. Are there any fellow owners with the same model who can offer some advice? The CVT inspection is really giving me a headache. Fellow car enthusiasts, please share some tips!
For the 2017 BRZ, the lower trim and higher trim, specifically the S and RS versions, besides the difference in suspension, is there a difference in the central control? I noticed some websites show the RS version with a touchscreen central control while others show it with a basic single-disc radio central control.
Hey guys, need some help! Has anyone experienced the car suddenly braking on its own? The dashboard shows braking, but there's nothing in front.
Help, everyone! Has anyone experienced this? While driving, the dashboard suddenly shows "brake," and the car brakes automatically, even though there's nothing in front.
I ordered the 2024 X version in-stock car, and it shows Santorini Black. But I see the 2024 models are called Meteorite Black. Why are they different? Can anyone help explain my confusion? 😊
