Hey car enthusiasts, when I put my 4WD on a lift, the front wheels spin but the rear ones don't. After a while, it shows a "4WD Overheat" warning. But when I drive on the road for a bit, the error code disappears.
Has anyone encountered a situation where the 2017 Smart car doesn't respond when put in reverse gear, and the engine warning light is on?
How should I use the 4WD in the FJ when alternating between icy and dry paved roads?
What are the issues when the warning lights for these fault codes appear on a 2015 MG GT?
4Today, I went to the 4S shop to change the oil. When the car was lifted, I tried spinning one of the rear wheels by hand, but the other rear wheel didn't move. For a four-wheel drive, shouldn't turning one wheel cause the other to spin in the opposite direction, like the front wheels do? Can someone explain if this is normal?
5Guys, today I tried flooring it in Sport+ mode and heard a rustling sound that lasted about 5 seconds before disappearing. No error codes on the dashboard, and the car drives fine. However, when I parked and shifted to P, there was a continuous electrical noise. The noise disappeared after switching to neutral and back to P. Could there be an issue with the transmission? How should I check it?
6Hey car enthusiasts, when I put my 4WD on a lift, the front wheels spin but the rear ones don't. After a while, it shows a "4WD Overheat" warning. But when I drive on the road for a bit, the error code disappears.
7When braking, does this taillight light up? After the dashboard is powered on, all the fault codes light up, but they all disappear once the engine starts. Is this situation normal?
8What's the real-world range of this 4WD version on city roads if I don't deliberately control the throttle?
9Do you feel that the chassis of your Xiaoqi feels a bit loose when going over rough and hard surfaces, like uphill and downhill? Mine feels a bit loose, and it's only 20,000 kilometers in. I usually don't drive on rough roads, just once on a mountain road with stone slabs and once over a speed bump in the parking lot, and it didn't feel good.
10I have a Haima S5 with an automatic transmission, and occasionally the transmission warning light turns on. But when I press the brake, it goes off! When I try to read the error code, nothing shows up. What could be the reason?
