فهد رومي
2023-03-29 10:52
For a 12-year-old car that has already run 190,000 kilometers and is experiencing a lack of power when starting, it's generally recommended to use a high-mileage engine oil. High-mileage oils are specially formulated to help reduce oil consumption, minimize leaks and oil seepage, and reduce smoke and emissions in older engines. They also contain additives that help condition seals and protect worn engine parts. You might want to consider a 10W-40 or a 5W-30 high-mileage oil, depending on your climate and specific engine requirements. Always refer to your vehicle's manual or consult with a professional mechanic for the best advice tailored to your car's condition and needs.
خالد كم
خالد كم2023-04-10 21:26
Mobil full synthetic oil change every 10,000 kilometers.
عبدالرحمن عوادة
عبدالرحمن عوادة2023-04-09 22:35
It depends on which region you are using it in.
My 2018 automatic car with a turbo is losing engine oil. I've checked with the service center; there's no blue or white smoke from the exhaust, and there's no sign of oil leakage on the engine exterior. Both the oxygen sensor and spark plugs are clean. The service center couldn't find the problem. Anyone knows what might be wrong?
What type of engine oil should I use for my X95? Is it the same type for all mileages? I'm currently at around 8,000 kilometers...
Does your engine cylinder head leak oil?
It's a common issue. The big smell in your car during summer is usually due to the heat causing materials inside to release odors. When you turn on the air conditioning, it helps circulate air and reduce the smell.
For the 2023 Model X, there are several accessories you can consider to enhance practicality beyond the basic seat covers and floor mats, especially for your 5-seater version. Here are some suggestions: 1. **Trunk Organizer**: Helps keep your trunk tidy and maximizes space usage. 2. **Sunshade**: Protects the interior from heat and UV rays, keeping the cabin cool. 3. **Screen Protector**: Prevents scratches and reduces glare on the touchscreen. 4. **Wireless Phone Charger**: Convenient for charging your phone without cables. 5. **All-Weather Floor Liners**: Offer better protection against dirt and spills. 6. **Roof Rack**: Adds extra storage capacity for trips and outdoor activities. 7. **Console Wraps**: Personalizes the interior and protects from scratches. 8. **Portable Vacuum Cleaner**: Keeps the interior clean, especially useful for families or pets. These accessories can improve the functionality and comfort of your Model X.
Peugeot 206 automatic. Exhaust pipe leaking oil and emitting white smoke. The car can move on flat roads but the engine shakes. It lacks power going uphill. What's going on?
Does your Santana's engine shake when you turn on the air conditioning for cold air?
How is the overall condition of the Forester models from 2019 onwards with high mileage?
