During the rainy season, my car has been parked outside for the past few days. After starting the car and pressing the brakes, I hear water sounds from the chassis. I've checked the sunroof and there's no leak, also tested the floor, and it's fine. Could it be that the frame has taken in water? Can any expert analyze this?
There have been heavy rains these past few days, and the driver's side is leaking, with the A-pillar being wet. Could it be that the sunroof is blocked? Or is there another reason?
Guys, has anyone taken the Grand Cherokee off-road? What level of intensity? Will the unibody frame deform if you go too hard? I've had it for five years and haven't taken it off-road yet. I tried with the Compass before and ended up getting all four wheels off the ground on a dirt mound—still got some trauma from that.
4Hey Swift buddies, can someone tell me where the water leak is if there's water accumulating under the rear seat on the driver's side during rainy days? There's no water anywhere else, just this spot on the left side of the rear seat.
5Jetur X70, 2020 model. I started having a coolant leak, and when pressure was applied, the leak point was found. The four-way valve was replaced, and the heating pipe and water inlet pipe were tightened. It was also discovered that the water pump was leaking, and eventually, everything was replaced. However, after refilling the coolant, the mechanic found that the engine temperature was high, but it drops as soon as the heater is turned on. They spent half a day but couldn't find the problem, and the car not being fixed has caused a lot of issues. Have you encountered this before? How did you handle it?
6What's causing water under the passenger seat and rear floor mat of the Haima S5? Where is it leaking from? If anyone knows, please reply, thanks!
7Has anyone experienced water leaking onto the passenger side from the AC? The AC drain pipe isn't clogged and it's draining water. Could it be that there's water inside the evaporator box?
8Why do I hear a sharp "squeak" sound when releasing the handbrake? This has only started happening in the past year.
9Hey everyone, I bought my car in December 2019. I haven't driven it much in the past two months, and it's been quite rainy. I've noticed some rust in this spot. Does it affect the car? Do I need to address it? Also, when I just started driving, it felt like one of the tires had a bulge, but after checking, all four tires seem fine. Has anyone experienced something similar?
