فهد خلف
فهد خلف
Nov 19
Is there any Tank 300 owner experiencing a rattling noise from the passenger armrest while idling? It's an annoying sound, and the dealership hasn't been able to fix it.
حسين سامر
حسين سامر2024-11-21 06:19
I felt the steering wheel and the whole car shaking during the test drive of the new car, so I gave up.
محمد تكريتي
محمد تكريتي2024-11-20 09:07
Putting it in neutral won't matter [I need some peace]
محمد تكريتي
محمد تكريتي2024-11-20 09:06
I feel the same way. The steering wheel has a slight vibration.
Hello everyone, I have a 2011 Comfort M5, and I've had it for a year and a half without any issues. Recently, there's been a rattling noise on the front passenger side when driving on regular concrete roads, like the sound of knocking on wood, which is quite annoying. There's no noise on highways or asphalt roads. What could be the reason for this?
How to fix the rattling noise in the trunk of a V93 while driving? Looking for advice from experts.
The passenger seatbelt outlet keeps making noise while driving, it's too loud. How can I fix it?
After driving my car for a while, I keep getting notifications that the transmission needs maintenance. I've gone several times but it hasn't been fixed.
2018 model, two-door F56, there is a continuous and noticeable thumping sound from the right rear of the vehicle at idle. I've checked it myself, and when I unscrew the fuel cap, the sound stops immediately. Once I put it back on, it starts again after a while. If I cover the fuel cap with my hand, the sound stops right away, but once I remove my hand, it starts again. I suspect it has something to do with a component related to the fuel tank, perhaps the charcoal canister or the fuel tank vent? Anyone knowledgeable can help? I feel like I'm close to solving the problem, can someone assist?
Hey buddies, does anyone have a rattling noise from the passenger side dashboard? My car is from 2021 and has less than 60,000 km. It happens when I turn on the power, while driving, and sometimes even when it's off. The noise also appears when I turn on the AC and occasionally when using the wipers.
I've had my Ousheng for a year now, and after 15,000 kilometers, the engine started making a rattling sound like a tractor! I went to the 4S shop and they updated the software, which fixed it. Will this problem happen again in the future? I know a lot of people have faced this issue. If your car hasn't had this problem, please let us know. And for those who have experienced it, please share how you resolved it. 🙏🙏🙏
Hello everyone, I have a question: My Mazda 6 had the engine light and oil light come on after shifting to neutral while waiting at a traffic light. The idle was normal, but there was no response when I pressed the gas pedal and shifted to drive. After restarting the car, everything went back to normal. I went to the dealership, but they couldn't find any error codes. Has anyone experienced something similar? How can I fix it?
Hey everyone, when I'm driving on the highway, there's a strange noise coming from under the steering wheel. It's not constant, just on and off, and it's really annoying! I've been to the dealership, but they couldn't completely fix it. Has anyone else experienced the same issue?
Nissan Pathfinder
Nissan PathfinderSAR 116,185 ~ 253,935Gasoline & Petrol
