عبدالرحمن مصطفى
2024-10-13 17:03
Do you have issues with window noise? When the car is parked outdoors, during rainy or very hot days, after starting, there's a creaking sound from the rooftop or windows, which disappears after driving for a while. I should mention that if it's parked in an underground garage, there's no noise. Even after reopening and closing the sunroof, the problem persists. When the noise occurs, it gets louder if the road is uneven. The model is a six-seater.
علي حازم
علي حازم2024-10-23 13:29
I had the same issue. Went to the shop and the technician just tightened the screws.
حسن طيب
حسن طيب2024-10-14 15:27
Just go to the shop and adjust the screws.
Does your engine shake after the first maintenance? Mine is shaking quite a bit after today's first maintenance, and the engine noise is louder than before!
Why does the air conditioning compressor keep making noise for a few minutes after parking and locking the car? What could be the reason?
Has anyone encountered a humming noise coming from the left rear wheel of their Defender 110 after parking? The sound stops after about 3 minutes, and there's no noise from the other wheels.
I got the RDX Premium 2WD on June 16, 2022. After parking it in the garage for 45 days while I was on a business trip, the battery was dead when I returned. The RDX's battery is really frustrating!
When the air conditioning blows cold air for a while and then switches to hot air, and after being turned off for a bit, it works again before reverting to hot air, it's puzzling. Interestingly, this issue doesn't occur on rainy days or when the weather isn't too hot. What could be the cause of this situation?
I have a Maserati Quattroporte. Recently, when parked under the sun, the AC blows hot air, but after parking overnight in the garage, it works fine again. This keeps happening repeatedly. Does anyone know what might be the cause?
What's causing the creaking sound from the chassis when I get out of the car in the garage? The echo in the garage makes the sound louder. Has anyone else experienced a similar issue? I have a 2021 model that I've driven for 20,000 km over two and a half years. When parking, I stop completely, shift to neutral, engage the electronic handbrake, then shift to park, turn off the engine, and get out. That's when I hear a creak from the left rear side.
Automatic parking makes a creaking noise when I press the accelerator to start. How can I fix this? It's not yet time for the first maintenance.
The front windows of the Jetour X70 cannot be opened, and the horn alarms when the car is locked with the remote. When the unlock button on the remote is pressed and held, only the rear windows open, while the front windows do not respond. I had this issue repaired at the 4S shop before, and they said it was related to the fuse. However, the problem has occurred again just two to three months after the repair.
Nissan Nissan Pathfinder
Nissan PathfinderAED 158,000 ~ 220,797Gasoline
