سعود ميك
سعود ميك
Dec 5
Passat 330-2023 facelift, the sensor-based opening method for the doors and trunk suddenly stopped working. When I put my hand on the door handle, the key fob is responsive (the small red light on the key fob lights up). What could be the issue?
بدر حسين
بدر حسين2024-12-06 06:48
Put a band-aid on it [grin]
حسين نور الله
حسين نور الله2024-12-06 00:29
Is it time to wash the car, or is something blocking the radar?
The car wouldn't start just now, and the screen didn't light up. I couldn't unlock it with the key fob either, so I had to manually turn the car door open with the key.
When I put it in drive, the engine stalls. I have a 2017 model 95 with over 70,000 kilometers now. Recently, I've encountered a problem where the engine stalls when I put it in drive while waiting at a red light. It's happened a few times already, but the 4S shop couldn't find the issue. Has any fellow car owner experienced this problem?
Does anyone know how to set up the feature where you can unlock the car by bringing the key close to the handle and lock the door by pressing the handle?
After leaving the 2012 Koleos in an open-air parking lot for half a month during heavy rain, the keyless entry on the front doors suddenly stopped working, while the rear doors are fine. Has anyone experienced this situation? Is it a wiring issue or are the keyless entry sensors malfunctioning? PS: It's not a key battery issue.
What should I do if the key of the 2022 HS7 can't open the tailgate, and the sensor can't lock the car doors? Thanks.
Hey car enthusiasts, have you ever experienced the trunk opening when you press the car key to unlock or lock the car? The sensor works fine for opening and locking the doors! But when I use the key to press the trunk button, it opens. What's going on??
Today I was driving my MG One and stopped at a red light. I put the car in park, and when the light turned green, I shifted to drive. Suddenly, the car system reported that the battery was dead and there was an engine fault code. The car wouldn't move even when I pressed the gas. After turning off the engine and restarting the car, it was able to move again, and the fault code disappeared. I went to a friend's repair shop to check, but they didn't find any issues. Since I was at the traffic light and the car behind kept honking, I didn't have time to take a picture. I'm a bit regretful about that. When I go to the 4S shop, I'm not sure how to explain it.
I found a problem today, the taillights flashed by themselves. My friend and I were outside the car, the doors were locked, and we were less than two meters behind the car. The key was in my pocket, and the taillights flashed twice on their own, with about a thirty-second interval! What's going on!!! It's different from the hazard lights, it was a quick flash on and off. Is it haunted? 👿👿👿👿👿
Volkswagen Passat
Volkswagen PassatAED 95,000 ~ 131,000Gasoline & Petrol
