أبو بكر سعود
أبو بكر سعود
Dec 5
Hi everyone, I have a question about my 2024 Passat 380 Luxury with around 4700 km on it. When I reverse with the brakes applied, there's a strange noise, but it doesn't happen the second time I try it. What could be the reason for this? Any advice would be appreciated.
عبدالرحمن بكر
عبدالرحمن بكر2024-12-06 11:00
Is it a buzzing noise? Check the brake pads and brake discs.
سلمان ق
سلمان ق2024-12-06 03:00
What kind of noise? Can you describe it? Like a clunking sound?
Hey guys, I have a question about the 2006 Peugeot 206 1.6 with the semi-automatic transmission. When I put it in reverse gear, the reverse lights don't come on. What could be the issue?
I just got the 2021 luxury version of the GV80. I'm wondering if I need to apply a front windshield film and window film. Also, for a dash cam, which type can be hidden without needing wiring? Looking for some expert advice.
I just drove my new 2024 380 Luxury for over 100 kilometers, and I'm feeling vibrations in the accelerator pedal when I accelerate. What could be the issue? Do any fellow car enthusiasts experience this too?
Whenever I used to brake, my Land Cruiser would occasionally emit a beeping sound, similar to the reverse radar sound. Recently, it happens every time I brake. Does anyone know what the issue might be?
Hello to all the Sunshine car owners in the circle. I have a question: What could be the reason for my car's idling stutter, stutter when accelerating, and steering wheel shaking when braking? Please, I would appreciate any help with this.
Hey everyone, I've been experiencing some jerking when I press the clutch on my car. What could be the reason for this? It happens when I try to shift gears at 2000 RPM.
Hi everyone, I have a question about my 2016 Nissan Sunny. Sometimes the car won't start on the first try, but if I turn the key off and try again, it starts. This happens every time I start the car. I've had the battery checked and it's fine, and I've also had the starter cleaned and maintained, but the problem persists. Does anyone know what could be causing this issue?
When I put my 2019 GA6 in drive, there's a motor sound like a "squeak," but it doesn't happen in reverse. Is this normal, and do you have any ideas about it?
When I suddenly shift to reverse gear, the 360 camera doesn't display. The screen isn't even black; it shows nothing at all. Do you have any idea what could be happening?
Has anyone used cruise control on the luxury edition? I haven't used it before. I tried it on the highway, but it didn't respond. Am I doing something wrong? Any advice would be appreciated.
Volkswagen Passat
Volkswagen PassatSAR 100,870 ~ 167,250Gasoline & Petrol
