I'm planning to buy a Panamera soon. Initially, I was considering a regular Panamera with options totaling around 140. But I recently discovered that the new Active Ride can only be selected on the e-Hybrid, which is about 16 more expensive even if I forgo some options. Can any owners share whether the Active Ride feature is worth the money? Is it cost-effective?
Where can I set the three options for the V40 active braking system?
4How should I choose my first car? Is it better to buy a new gasoline car or a used electric car? The new car is a fully equipped gasoline version of Haval H5 with all optional features. The used car is a Hongqi electric vehicle, the Hongqi E-HS9.
5Braking Dipping. I'm considering getting a standard 911. After a test drive of the 4S, I noticed a braking dipping issue. Even if I slowly release the brakes at the last moment, there's still a forward lurch just before coming to a stop. My current Mercedes doesn't have this issue, and neither did the Panamera I test drove earlier. Is it a matter of selecting the wrong mode, or is the car designed this way?
6Are you torn between the G80 and the Mercedes E? I'm currently driving an XC60, and honestly, Volvo's resale value in the domestic market is disappointing. I initially thought I wouldn't care and would drive it for 10 years, but the reality is that I'm planning to switch in less than 7 years. Considering the future resale value of the G80, I'm a bit conflicted.
7Seeking advice on buying a car. Currently driving a Mercedes E-Class. My business is stable, earning 20,000 daily, working all year round. I’d like to ask about the comfort level of the Porsche Panamera Executive compared to the Mercedes E-Class. I'm only 35, and moving to a Mercedes S-Class feels like admitting I'm getting old. I value comfort a lot, and buying two cars seems too wasteful.
8I'm planning to buy a Panamera soon. Initially, I was considering a regular Panamera with options totaling around 140. But I recently discovered that the new Active Ride can only be selected on the e-Hybrid, which is about 16 more expensive even if I forgo some options. Can any owners share whether the Active Ride feature is worth the money? Is it cost-effective?
9Nissan X-Trail e-Power, I have two questions: 1) When the door is opened in D or R gear, the car alarms, but it doesn't shift back to P gear. Is that correct? I seem to remember it would automatically shift back to P gear before. 2) The speed-sensitive setting for the front wipers is on, but it doesn't seem to activate automatically when it rains. Why? Thanks for the explanation.
