Pajero V93 chassis is leaking oil, and it's dripping onto the exhaust pipe. It needs repair.
Peugeot 206 automatic. Exhaust pipe leaking oil and emitting white smoke. The car can move on flat roads but the engine shakes. It lacks power going uphill. What's going on?
Is the left side of the Jeep Compass exhaust pipe naturally lower, or does it need to be fixed?
414 model, 1.5T, exhaust pipe doesn't emit blue smoke, but there's significant oil consumption. Can any expert shed some light on this?
5Do you need to modify the exhaust header on a new car? Replace the GPF with a straight pipe? Prevent blockage?
6My 2009 Peugeot 307 has a transmission oil leak. I had it repaired once, but it's leaking again. The mechanic said that taking it apart for repairs would cost thousands and it's not worth it anymore. He suggested just adding some oil from time to time.
7In 2009 Peugeot 307, the gearbox is slightly leaking oil. The mechanic said that if you want to repair the gearbox, it would cost a few thousand. If the leak isn't serious, you can just leave it and regularly add gearbox oil.
8Has anyone experienced water leaking onto the passenger side from the AC? The AC drain pipe isn't clogged and it's draining water. Could it be that there's water inside the evaporator box?
9This pipe seems to be leaking oil. Does this happen to you as well? Also, what is the purpose of this pipe? Is it for exhaust gas recirculation?
10Hey everyone, quick question: What's the outer diameter of the exhaust pipe for a Nissan Sunny? Need to buy a fire cap to put on it.
