سلمان يوسف
Oct 6
Is the 2019 model V97 using 92 or 95 fuel?
Which fuel is more fuel-efficient for the 2011 Ford F150, 92 or 95?
Fellow car enthusiasts, should this car use 92 or 95 octane fuel? What's the fuel consumption per 100 kilometers?
Can the 2019 4WD model use 92 octane fuel?
4I want to ask, for the 2002 model with a 2.4 engine, if I switch from using 95 to 92 fuel long-term, will it cause any issues?
5What do you think, is it better to use 92 or 95 for better performance? I've always used 95, but I've heard that 92 might give more power.
6Does the 2011 MDX use 92 or 95 octane fuel?
7Is the 2019 model V97 using 92 or 95 fuel?
8Should I use 92 or 95 gasoline for the 3.6 version?
9In 2022, the car required 95 octane fuel, but for the 2024 model, it uses 92 octane fuel. I checked and it seems like nothing has changed. Why is that?
10I've been using 95 octane fuel for two and a half years. Should I continue with 95 or switch to 92? Thanks.
