How to solve high water temperature issue in V73?
What could cause high water temperature if the water pump and thermostat are not the issue?
When driving, if the electronic fan does not start at high speed after turning on the air conditioning and the water temperature is high, how can this be resolved?
I've never encountered an issue with high water temperature in my car. There's no water leakage. What could be the problem?
4Where is the water temperature gauge?
5I want to ask, I bought a new car and have driven 2000 kilometers, the car is overheating, and the water temperature gauge shows 90 degrees. How can I solve this issue?
6How to solve high water temperature issue in V73?
7Can the data such as water temperature and oil temperature be displayed?
8How did you deal with the issue of the water temperature sensor malfunctioning and the temperature light constantly flashing? I replaced the temperature sensor, but it started flashing again after two months. Did you replace the thermostat assembly? 2017 model.
9How do you check the water temperature on a 2010 Legacy Luxury Navigation Edition?
10What's your water temperature?
