Hi everyone, when replacing the original navigation system of a Chinese-spec 93 with a used one, the speedometer isn't working. What could be the issue with the fault code?
Hi everyone, the steering wheel buttons on my C30 can't switch songs, but the volume control works. What could be the issue? I've installed a navigation system.
Hi everyone, could you please help me with how to use the projection feature on the 2019 flagship MPV? I've been trying for a while but can't seem to make it work. Also, the car system doesn't have a built-in navigation system.
After replacing the battery in the MDX vehicle, a fault code appeared, and it cannot start.
4Has anyone replaced the central control system on cars after August 2019? If you removed the original system, did it trigger an engine fault code? How did you resolve it?
5Hi everyone, can the phone navigation be connected to the V40 via Bluetooth if the original car doesn't come with a navigation system?
6Hi everyone, when replacing the original navigation system of a Chinese-spec 93 with a used one, the speedometer isn't working. What could be the issue with the fault code?
7I changed to a large screen on my V93 and now there's a fault code. The odometer isn't working, and the mileage isn't displaying. Can any experts advise on how to fix this?
8Is the original navigation system in the T-Cross Comfortline easy to use?
9Hi everyone, how come the car USB music on the Chery Tiggo 1.5L Luxury isn't working?
10Hi everyone, what's the maximum speed of the Navigator?
