مجدي خالد
2023-10-11 18:49
Have any of you experienced both D and N lights on at the same time? Why does my '93 have this issue after driving through water?
حسين عمار
حسين عمار2023-10-11 21:50
The gear shift paddles got water inside.
When the old model Vito is at a red light and you shift from N to D, causing the car to lurch forward, what could be the reason?
Why did the engine warning light turn on and the D gear light keep flashing after driving my 2014 Honda City automatic on the highway for three hours?
Why is the stability control light on and the handbrake not working? Anyone else experiencing the same issue?
Hey car enthusiasts, any idea why the 2023 X90 Zilong Changsheng edition's hazard lights automatically flash 10 times after turning off the engine?
The turn signal is intermittently malfunctioning. Most of the time, it fails when the headlights are turned on—there's no light or clicking sound. Once the headlights are turned off, it works fine again. Has anyone else experienced the same issue?
Hey guys, I have a 2019 Kicks. When I'm waiting at a red light and switch to N gear, then back to D, the acceleration feels noticeably slower. Has anyone else experienced this?
After washing the exterior of the T-Cross, why are all the dashboard lights on?
I just noticed that when I try to spray water, the wipers just move without any water coming out. Both nozzles aren't spraying. Has anyone else experienced this issue?
