When braking, does this taillight light up? After the dashboard is powered on, all the fault codes light up, but they all disappear once the engine starts. Is this situation normal?When braking, does this taillight light up? After the dashboard is powered on, all the fault codes light up, but they all disappear once the engine starts. Is this situation normal?
عبد العزيز بشار
2024-08-29 07:07
فهد قاسم
فهد قاسم2024-08-29 15:15
That's the brake light, it should definitely be on. Fault codes are all lit up, that's normal.
2
After the power reset of the Coaster, the fault code light is on and it can't accelerate. What's going on? Can any expert advise, please?
Why does the transmission often show a fault code and then disappear on its own shortly after?
What are the issues when the warning lights for these fault codes appear on a 2015 MG GT?
After the vehicle inspection, a series of warning lights for ABS, ESC, electronic parking brake, and hill-start assist light up. Usually, they don't light up when I start driving, but after a while, they do. I went to the repair shop to clear the fault codes once, but after driving 20 to 30 kilometers, they came on again. Does anyone know what the cause might be?
MG ZS intermittent engine fault code. It disappears and then reappears, how to deal with it?
Is it normal for the right taillight not to light up?
I have a 2016 Haval H2. Have any of you experienced a brake light fault warning when pressing the brake pedal for a long time, but the warning disappears once you restart and press the brake again?
The engine won't start, and the EPC, battery, and engine fault lights on the dashboard are all on. What could be the reason?
Mitsubishi Mitsubishi Outlander
Mitsubishi OutlanderAED 96,495 ~ 153,000Gasoline & Hybrid
