عبدالرحمن كريم
2024-09-02 06:34
What's this fault, does it have a big impact?
Comments( 7 )
سعود وي2024-09-21 14:53
In winter, tires expand and contract with the temperature changes, causing the tire pressure to drop. If it drops to 2.2, you'll get an alert. Just add some air and you're good to go.
عبد العزيز مساعد2024-09-20 19:17
The tire pressure is low. It needs to be inflated to 2.8.
علي نصر2024-09-08 20:18
Inflate to 2.6 is fine.
عمر حريري2024-09-08 20:06
How to wash it? It's always like this in winter.
حسن رمضان2024-09-08 19:31
Maybe something got punctured.
حسن جم2024-09-06 06:38
Low tire pressure.
نايف بكران2024-09-02 17:53
The tire pressure is low. Just find a repair shop to inflate the tires.
2
What should I do if there's a fault with the BLIS and CAT systems?
Hey guys, the dust boot on the control arm ball joint is torn. Is it necessary to replace it? Will it have a big impact if I don't?
Does the Nissan Kicks have a rear impact beam?
4What should I do if there's an airbag fault in my Touareg?
5Does the alternator occasionally not charge and cause a fault alarm? Should it be replaced?
6Engine shows fault code, acceleration is weak, what could be the reason?
7What impact does the bankruptcy of HiPhi have on the daily use of this car?
8Why doesn't such a big car have rear-wheel steering?
9What's this fault, does it have a big impact?
10Does accidentally triggering the hood switch and driving in the rain (light rain) have a big impact?
