This morning while driving, there was a sudden jolt as if the car was about to stall, but then it was fine. Has anyone experienced this? What could be the issue?
Comments( 10 )
Is there a delay in acceleration when refueling while driving, followed by a sudden jolt sound? Has anyone experienced the same situation?
What could be the reason for the 2018 BMW X1 stalling automatically in Drive? Has anyone encountered this issue?
Why did the Haima S5 suddenly stall while driving?
4Do you guys have issues with the passenger airbag showing error codes? Mine was fine in the morning, but in the afternoon, it started showing an error code. Have you experienced this?
519w km, the vehicle suddenly stalls while driving. What could be the issue?
6My car has been driven 90,000 kilometers since 2013. It's shaking when idling, and there's a jolt when shifting from Neutral to Drive. Has anyone else experienced this issue? Could it be time to replace the engine mounts?
7Has anyone experienced their head-up display flickering while driving?
8This morning while driving, there was a sudden jolt as if the car was about to stall, but then it was fine. Has anyone experienced this? What could be the issue?
9After starting the 2019 Taurus, the steering wheel won't turn in place, even when reversing. It only turns when reversing while moving. However, it works fine when driving forward. Has anyone experienced this issue?
10In the morning, when starting the vehicle and driving at low speeds, it occasionally stalls. I've already cleaned the throttle and injectors, but it still stalls sometimes. If the speed picks up, it doesn't stall. What could be the reason? 🤦♂️
