The car often reports that it can't detect the key as soon as I open the door... The key is a replacement. What's going on?
How can I properly open the dash cam card slot? I can't pry it open with a key.
The trunk of my Scirocco can't be opened using the driver's seat switch, but I can open it with the key. What's going on?
The trunk door of my X-Trail can't be opened or closed manually (I can hear a click from the manual button, but the door doesn't pop up automatically). However, it can be opened with the key. What could be the issue? Please help, thank you 🙏
4What should I do if the key of the 2022 HS7 can't open the tailgate, and the sensor can't lock the car doors? Thanks.
5What could be the reason that when I press the key, the car doesn't respond and the doors won't open?
6Hey car enthusiasts, have you ever experienced the trunk opening when you press the car key to unlock or lock the car? The sensor works fine for opening and locking the doors! But when I use the key to press the trunk button, it opens. What's going on??
7How can I prevent the rear lights from turning on as soon as the door is opened?
8What can I do if the key is not detected? Does anyone know?
9The car hasn't been driven for just two days, and the door can't be unlocked. I used the mechanical key to open the door, but there's no power at all inside. What's going on?
10The car often reports that it can't detect the key as soon as I open the door... The key is a replacement. What's going on?
