I've got a 2020 Outlander 2.4 Zhixiang edition, and it's only driven 170 kilometers. When it's idling, there's a noticeable "da-da-da-da" sound inside the car. Can any expert explain what might be causing this?
Foton Tunland E7, a car from September 2020, has been driven for over 10,000 kilometers. The gear grinding issue when shifting into reverse is very serious. Can any expert provide some guidance?
When turning on the air conditioning in my 2006 Previa ACR50, I occasionally hear this sound. Can any experts help explain what's happening? Has anyone experienced a similar issue, and what could be the cause? It's a 2.4.
I've got a 2013 Kia Sportage Manual GL 2.0, and the steering wheel shakes when idling. I've cleaned the carbon buildup in the engine cylinders, the injectors, and the idle valve. I also replaced the spark plugs and engine mounts last year. Any experts out there have any advice?
4Is anyone else experiencing noticeable idling vibrations? 😂 Just got the car, and it drives smoothly, but the idling vibrations are quite strong. Is anyone else having a similar issue?
5I just got the Middle East 5.6, and I noticed that in daily use, the car mostly runs at idle speed, not even reaching 1500 RPM at 100 km/h. Will long-term low RPM driving lead to carbon buildup? I need advice from experienced experts.
6I'd like to ask fellow car enthusiasts a question. For the 2020 4WD Elite Edition Jeep Compass, is there a button inside the car to open the trunk? I've been opening it from the outside directly for four years. Does anyone know?
7I'm considering buying a used Mitsubishi Outlander 2.0 Comfort Edition, registered in 2020 with over 40,000 kilometers. It has an accident record with a replaced front bumper. I'm wondering if the engine is reliable and if repairs are expensive. Could any experienced owners share their insights?
8Can the 2021 2.4 Outlander Dynamic Edition have a cargo cover installed in the trunk?
9Does anyone feel that the idle vibration of the 2024 Macan S is a bit much? Just got the car, over 100 kilometers on it, and sitting inside feels shakier than my 4-cylinder BMW... Anyone else feel the same?
10My 2021 Outlander's trunk suddenly won't open (can be opened with the emergency button inside). The lock button on the driver's side isn't working properly, can't lock the car. Any experts know how to fix this?
