How do you guys change the transmission oil, gravity or circulation?
How often should the transmission fluid be changed?
4Is it necessary to change the transmission fluid for a 2010 Suzuki SX4 Hatchback 1.6 Automatic that has traveled 160,000 kilometers and hasn't had a transmission fluid change yet? The gear shifting is currently very smooth.
5Q: For the Taurus 8AT transmission, is it necessary to use a circulation machine to change the transmission oil? Is it required to remove the oil pan for cleaning?
6Has anyone changed their transmission fluid? How many liters did you use? Did you do a gravity change or a full cycle change???
7Has anyone in the group changed the transmission oil for the 2021 JMC Ford Territory? This model doesn't have a transmission oil filter. Is it better to do a fluid exchange or a gravity drain by removing the oil pan? 🙏🙏
8How do I change the transmission oil for a Mazda 6 AT? Should I use the circulation method or the gravity method? It's currently at 76,000 kilometers.
9I've driven my 2024 Wrangler for 10,000 kilometers. The first service was done at the 4S shop at 5,000 kilometers. They suggested I service it again at 10,000 kilometers. Do I need to change the engine oil this time?
10How often should transmission fluid be changed? I bought my Outlander in July 2020, and it has been four years with only 10,000 kilometers driven. However, the dealership says it's time to change it due to the time elapsed, or else the warranty won't cover transmission issues. Has anyone here changed their transmission fluid? Did you use the mechanical circulation method or the gravity method? With just 10,000 kilometers, do I need to remove the oil pan for cleaning before changing?
